Renault Megane II F1 Team
Publicado por Marito, Octubre 04, 2006, 09:49:14 AM
Marito
Marito
Marito
Exterior Equipment
ââ,¬Â¢ 18" Alloy Wheels
ââ,¬Â¢ Smart "Flat-blade" windscreen wipers
ââ,¬Â¢ Front fog lamps
ââ,¬Â¢ Chrome double outlet exhaust
ââ,¬Â¢ Headlamp washers
ââ,¬Â¢ Double Optic automatic headlamps with "see me home" function
ââ,¬Â¢ Automatic windscreen wipers
ââ,¬Â¢ Satin chrome door handles
ââ,¬Â¢ Fuel Flap With Integrated Fuel Cap
ââ,¬Â¢ 60:40 Split/Folding Rear Seats
Interior Equipment
ââ,¬Â¢ Air conditioning
ââ,¬Â¢ 4 x 15w single CD /RDS radio with fingertip control
ââ,¬Â¢ Leather steering wheel and gearknob
ââ,¬Â¢ Cruise control with speed limiter
ââ,¬Â¢ Sports front seats
ââ,¬Â¢ Keyless car with Renault Card
ââ,¬Â¢ Puncture Repair Spray ilo Spare Wheel
ââ,¬Â¢ Electric Front Windows (One Touch)
ââ,¬Â¢ Electric Rear Windows (One Touch - Hatch)
ââ,¬Â¢ Height & Reach Adjustable Steering Wheel
ââ,¬Â¢ Multi-Function Trip Computer & Warning System (inc Outside Temperature Gauge)
Safety & Security Equipment
ââ,¬Â¢ ABS with Electronic Brake Distribution (EBD)
ââ,¬Â¢ ESP (Electronic Stability Programme) with CSV Understeer Control and ASR Traction Control
ââ,¬Â¢ Front/rear curtain airbags
ââ,¬Â¢ Driver's two stage adaptive airbag
ââ,¬Â¢ Front passenger's two stage adaptive airbag
ââ,¬Â¢ R.A.I.D. (Renault Anti Intruder Device)
ââ,¬Â¢ Insurance Approved (Categroy 1) Alarm
ââ,¬Â¢ Deadlocking
ââ,¬Â¢ Thatcham Approved Engine Immobiliser
Additional Equipment on Mégane Renaultsport 230 Renault F1 Team R26
ââ,¬Â¢ 4 x 15w single CD / MP3 compatible RDS radio with fingertip control
ââ,¬Â¢ Climate control
ââ,¬Â¢ Recaro Seats (Black / black SCOTEC)
ââ,¬Â¢ Silver-stitch detailing on steering wheel, gear knob and gaitor
ââ,¬Â¢ Renault F1 Team Plaque
ââ,¬Â¢ Renault F1 Team detailing on front, rear bumpers and roof (delete-option available)
ââ,¬Â¢ Modified Cup Chassis
18" Lightweight Anthracite Alloy Wheels
Anthracite coloured door mirror housings
Michelin Pilot Sport 235/40 R18
Red Brembo Brake Calipers
Drilled front and rear brake discs
Uprated front and rear spring rates
Re-tuned front / rear damper settings
Increased brake master cylinder diameter
Increased rear roll bar diameter
ââ,¬Â¢ Enhanced engine 230bhp and 200 g/km Co2 emission
ââ,¬Â¢ New Sports Exhaust with improved sound
ââ,¬Â¢ New Limited Slip differential
Marito
Aerodynamics
Drag Co-efficient/Area (Cd/A) 0.35
Body Type
No. of Doors 5
Body Type Classification Hatchback
Drivetrain
Number of Forward Gears 6
Gearbox Code ND0
Vehicle Speeds (mph) - 1st 5.6
Vehicle Speeds (mph) - 2nd 9.1
Vehicle Speeds (mph) - 3rd 12.8
Vehicle Speeds (mph) - 4th 16.9
Vehicle Speeds (mph) - 5th 21.9
Vehicle Speeds (mph) - 6th 22.4
Gearbox Type 6 Speed Manual
Capacities
Fuel Tank - Litres (Gallons) 13
Fuel Consumption
CO2 (g/km) 200
Urban - mpg (litres/100km) 24.6 (11.5)
Extra Urban - mpg (litres/100km) 47.1 (7)
Combined - mpg (litres/100km) 32.1 (8.8)
Steering
Number of Turns (Lock to Lock) 2.74
Turning Circle Between Kerbs/Walls (m) 10.35/11,25
Braking
Front Disks (Diameter mm) 312
Rear Disks (Diameter mm) 300
Engine
Fuel Type Unleaded Petrol
Injection Type Multipoint Injection
No. of Cylinders 4
No. of Valves 16
Induction Capacity (cc) 1998
Bore x Stroke 82.7 x 83
Compression Ratio 9:1
Maximum Power - kw ISO (hp DIN) 165 (230)
Maximum Power (revs/min) 5500
Maximum Torque - Nm ISO (mkg DIN) 300
Maximum Torque (revs/min) 3000
Performance
0-62mph (0-100kph) 6.5
Maximum Speed - mph (kph) 147 (236)
Weights
Kerb Weight (Excluding Driver) (kg) 1375
Gross Vehicle Weight (kg) 1820
Gross Train Weight (kg) 2550
Maximum Payload (Including Driver) (kg) 405
Maximum Towing Weight Braked - Driver Only (kg) 1000
Maximum Towing Weight Unbraked - Driver Only (kg) 650
Tyres
Size/Profile 225/40 R 18
Wheel Size 7.5 J 18
Suspension
Front Axle: Independent pivot arm with rectangular lower arm and anti-roll bar
Rear Axle: Torsion beam system, outboard attachment points with programmed deformation
Wheels Driven Front Wheel Drive
Seating
No. of Seats 5
Insurance Group 17E
Vehicle Type Number BM0M06
Minimum Load Volume (Litres or m3) 330/420/1190
Maximum Load Volume (Litres or m3) 1190
uliro
EL COCHE DE FERNANDO ALONSO
Renault España no podía dejar pasar la oportunidad de rendir tributo a Fernando Alonso, y de paso aprovecharse del tirón de la ââ,¬Å"alonsomaníaââ,¬Â. Por este motivo lanza una serie limitada de 150 unidades denominadas Megane F1 Team realizadas a partir del Megane Sport en carrocería tres puertas.
Un único color ââ,¬Å"azul F1 Teamââ,¬Â le identifica, así como las enormes llantas de aluminio de 18 pulgadas con diseño de 11 brazos que montan neumáticos 235/40 R18, o los ââ,¬Å"logos F1 Teamââ,¬Â en laterales y trasera del vehículo. En el interior figura bien visible en la consola central la placa con el número de serie, además de diversos bordados amarillos. A nivel chasis este modelo conmemorativo del triunfo de Renault y Fernando Alonso en la Fórmula Uno recibe también amortiguadores y muelles específicos, los cuatro discos de freno ventilados y perforados, y la posibilidad de desconectar el control electrónico de estabilidad ESP.
Mecánicamente estamos ante el mismo propulsor del Megane Sport, es decir un dos litros turbo de 225 cv con el que se puede acelerar de 0 a 100 km/h en ólo 6,5 segundos. Ya existe una versión todavía más racing de esta mecánica, la cual nació como homenaje a la Copa Megane Trophy, y que por consecuencia se denominan Megane Trophy. Estas versiones especiales convierten al Renault Megane en uno de los GTI más interesantes de un animado mercado en el que figuran automóviles tan codiciados como los VW Golf GTI y R32, BMW 130i, Opel Astra OPC, Ford Focus ST, etc.
Los 150 compradores de esta edición limitada recibirán un kit de regalos compuesto por camisa y gorra firmada y un lector de MP3 de 128 Mb. El precio a pagar por tan exclusiva versión es de 32.000 euros.
Clio Dynamique 1.6 16v
Javo ARC
como me calienta la put@ madreee
jac
Y si, no se puede negar es un misil....
Pappu
es hermoso!!! esas patas estan terribles... yo elegiria amarillo o azul!!
sael
que linda maquina por dios, lo peor de todo que TODOS LOS COLORES me encantan, no sabria cual elegir realmente...
Martin_RT
Es hermoso !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
El Interior me encanta, sobre todo el volante!! y el color me da lo mismo cualquiera !!! tan todos buenos !
JavitoClio
Por favor que buenas patas, que buenos asientos el interior la rompe, es un polvaso ese auto, loco eso esa arteeeee, Saludos
Lenny
Que lindo bicho!
Igualmente cuando lo vi en el stand de Renault en Pinamar, fue un shock.,..... el remate de la cola no es muy de mi agrado; pero con el tiempo vamos a estar acostumbrados.
Ahora que buena idea esta eh:
Cuando el paragolpes tenga un toquecito o raspon con la pintura.... se viene el calco renault f1 team :P
CARLONCHO
alguien sabe si esta nave va a llegar a la argentina???????????'
thepowerofhp
exelente!! el rojo sale como piña. con recaro y brembo,que mas pedir???
bastante interesante como acelera, le da pelea a la ultima generacion del golf gti y el civic SI.
un autazo!
Chiche
El color definitivamente es el deep black o Mercury.
No me parece que ande mucho para la facha que tiene.
