Chiptuning para Clio Sport
Publicado por SilverGti, Junio 13, 2005, 00:20:30 AM
tatu
Que lindo... hay de todo...
embragues, quick-shifts, suspension, strut bars, bujes, chunin, capots de carbono, jaula antivuelco, escapes de todo tipo, tamaño, material, y ruido, kit de forjados, intakes de aire frio de cf y de metal, kits de freno...
todo bolt-on, todo probado, solo hay q poner y salir a gastar nafta... que divertido seria vivir alla y tener la plata...
El kit ese esta lindo... 10 psi sin forjados, 240BHP, todo bolt-on, no hay que soldar nada... con forjados dicen q tira mas...
ojo, sale un huevo, pero trae TODO, y ellos lo colocan...
custom turbocharger, cast tubular manifold, forged ceramically coated low compression pistons, total seal piston rings, external wastegate for precise boost control, KTR front mounted intercooler with stainless steel intercooler piping, custom downpipe, uprated injectors, induction kit, dump valve, battery relocation kit, uprated clutch and ECU modifications to cater for the turbo conversion. There are also several smaller parts included to make a neat, reliable installation. There will also be the option of forged con rods for those wanting to run more than the standard 10psi.
